[postgis-devel] [geos-devel] RFC6 - Drop GEOS C++ API at GEOS 3.8
Bas Couwenberg sebastic at xs4all.nl
Mon Oct 2 00:30:28 PDT 2017
On 2017-10-02 09:13, Mateusz Loskot wrote:
>> As Bas said already it causes packagers headaches.
> So, the solution is to take the toys away from the kids...
Please help us understand your point of view. Why do you want to keep
the C++ API?
I like Sandros proposal to disable the C++ API by default and provide a
configure option to (re-)enable it combined with the header to state
that the developer has considered the downsides of using the C++ API.
It seems to address you concerns too, it doesn't take away your toy, it
just raises the barrier to using it because its a toy that can easily be
used to hurt others.
Kind Regards,
Bas
