[postgis-devel] RFC6 - Drop GEOS C++ API at GEOS 3.8
Regina Obe
lr at pcorp.us
Fri Oct 6 13:41:39 PDT 2017
Thanks Paul. I wasn't blaming osm2pgsql so much as just seeing this as a case study of a pattern of use that is a problem that must be more elevated.
For the real drop I decided to settle for a softer motion this time around.
Come 3.8 or 4.0, I'm going to repush for strk's proposition to throw an error unless the developer explicitly buys into the C++ API use.
For now as Bas mentioned I think things like GRASS may have a dependency on the GEOS C++ API they may not know about.
I want to see how many people notice the warning message we are going to put in and start ticketing those on projects as a problem :)
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Norman
Sent: Friday, October 06, 2017 3:58 PM
To: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] RFC6 - Drop GEOS C++ API at GEOS 3.8
On 10/1/2017 7:49 PM, Regina Obe wrote:
> As GEOS PSC member I vote +1 for dropping GEOS C++ API.
+1 (not PSC)
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
