[postgis-devel] PSC Vote: Change PostGIS library name to drop the minor
Regina Obe lr at pcorp.us
Wed Sep 6 09:00:59 PDT 2017
I want to itemize my key points
1) If we did not try to support PostgreSQL versions that couldn't fully support the key features of a PostGIS version, we wouldn't have such a mess with half-broken pg_upgrade installs.
That means we should never have supported anything lower than 2.2 in PostgreSQL 9.5 and not supported anything lower than 9.5 in 2.3 (the parallel stuff since we didn't do much with marking aggs as parallel safe in 9.5 ), it was okay to support 9.5 in 2.3.  2.4 should really not be supporting anything other than 9.6 and 10. I know it sound draconian but I really think it's the best for the majority of people.
If we feel really badly about supporting older versions then we've got to put a lot more work into it to prevent half-broken installs.
2) If we just called our library  postgis-2 instead of postgis-2.5 or whatever, then
All users will be coming from a lower postgis -- e.g. postgis-2.4.0 or postgis-2.3  etc.
We can provide a clean path for folks coming from lower versions because ALTER EXTENSION can recognize something needs to be done
For pg_upgrade  we can creating a symlink from older versions to postgis-2 and putting in all our dirty cleanup laundry in postgis-2.5 scripts to correct our past sins.
3) Moving forward don't try to let old versions pass just because they can't support a key feature of our new version.
Don't try to support newer versions of PostgreSQL with old code.  It makes us look like liars when people read the "Aha you can do this now literature" and they can't.
If our postgis library file was just called postgis-2   then we are free to do drop PostgreSQL versions as we see fit andnot impact anyone's upgrade path or screw up their install in a hard to fix way.
Thanks,
Regina
-----Original Message-----
Sent: Wednesday, September 06, 2017 11:34 AM
To: 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org>
Subject: RE: [postgis-devel] PSC Vote: Change PostGIS library name to drop the minor
>> It would also solve the issue we have that PostgreSQL 9.4 2.4 upgrading to PostgreSQL 9.6 2.4 is missing all the good stuff like true KNN and some parallel safe stuff we put in.
> No, this is untrue. The KNN and parallel stuff requires *scripts* rebuild and reload, so has nothign to do with the library/module.
> --strk;
I beg to differ again.
If a user has PostgreSQL 9.4 2.4 installed and they migrate to PostgreSQL 9.6 2.4
When they go to do
ALTER EXTENSION postgis UPDATE;
Nothing would happen.  It would say they are already current.  Even your favorite old-fashioned we have in place will not catch that.
However if they were coming from say
PostgreSQL 9.4 2.1  before we introduced all this KNN stuff and Parallel stuff that 9.4 can't use anyway -- but we let it pass (oh you can't support that lets not give you that).
Would run the bits we said you need to run to move from 2.1 to 2.4  which would be adding in the KNN logic, dropping and recreating aggs that need to be.
Sure you can argue we can add that in the future, but there is no way when we call a script 2.4.0 that ALTER EXTENSION postgis UPDATE would try to do anything.
Sure we could add another function and instruct users.
Oh and if ALTER EXTENSION postgis UPDATE says you need to do nothing, don't believe it.
Run
SELECT postgis_full_version();
Make sense of our gobbly gook
If you see a message that something to the effect yaddda yadda yadda, then run this
.sql script  which will update the function to update your code.
And then you are good.
How much freaking stuff do you expect people to do.
People are already struggling to type the words:
It's hard for both us and them.  Us to try to account for all the different versions of PostgreSQL you could have upgraded from and hard for them to make sense of what you are asking them to do.
You know how freaking hard it is to explain to users in training.  Oh that KNN stuff we talked about that is new in PostGIS 2.2., well forget about it if you are running PostgreSQL 9.4 or lower.
And if you hmm upgraded in the past some time using pg_ugrade, you don't get it either.  You need to fuck with your install or do a pg_dump / pg_restore.
Thanks,
Regina
