[postgis-devel] geom_name
Paul Ramsey pramsey at cleverelephant.ca
Thu Sep 7 10:52:32 PDT 2017
Hey BH,
This code from ogr_fdw might serve as a starting point
https://github.com/pramsey/pgsql-ogr-fdw/blob/master/ogr_fdw.c#L192
Each att in the row should have at atttyp I'd hope. Now, I'm not sure how
much
overhead a type type-lookup might have, hopefully not too much :)
We should ask about API changing, I'm sure Regina would say we're done,
which effectively means done-for-all-time, since changing public function
signatures is basically impossible one they are done.
P
On Thu, Sep 7, 2017 at 10:45 AM, Björn Harrtell <bjorn.harrtell at gmail.com>
wrote:
> Hi Paul,
> No good reason except that I couldn't find out a deterministic way to find
> it and put it out of my mind after that. :(
> With some guidance I'll be happy to revise the API if it's not too late at
> this point.
> /Björn
> 2017-09-07 19:41 GMT+02:00 Paul Ramsey <pramsey at cleverelephant.ca>:
>> Also, a bit late in the day, but why the text parameter "geom_name" in
>> these various signatures, instead of automagically finding it in the row?
>> P
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170907/59f05ff6/attachment.html>
