[postgis-devel] geom_name
Regina Obe lr at pcorp.us
Thu Sep 7 11:56:34 PDT 2017
> We should ask about API changing, I'm sure Regina would say we're done, which effectively means done-for-all-time, since changing public function signatures is basically impossible one they are done.
> P
I'm fine with you changing the API now before final 2.4.0 release.  I promised no new functions, not no new API changes to new 2.4 functions.
I think it would be good to drop the old signature in the postgis_drop_before.sql  since some people have already started using the MVT functions.
If it impacts existing code, we should also put in BREAKING CHANGE for postgis -2.4.0  the change so people are warned and know how to change their code if they were using an earlier postgis 2.4.0dev
Thanks,
Regina
On Thu, Sep 7, 2017 at 10:45 AM, Björn Harrtell <bjorn.harrtell at gmail.com <mailto:bjorn.harrtell at gmail.com> > wrote:
Hi Paul,
No good reason except that I couldn't find out a deterministic way to find it and put it out of my mind after that. :(
With some guidance I'll be happy to revise the API if it's not too late at this point.
/Björn
2017-09-07 19:41 GMT+02:00 Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca> >:
Also, a bit late in the day, but why the text parameter "geom_name" in these various signatures, instead of automagically finding it in the row?
P
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170907/64e1c39d/attachment.html>
