[postgis-devel] [postgis-tickets] r15732 - Add check-no-trailing-blanks Makefile rule and run on `make check`
Darafei "Komяpa" Praliaskouski me at komzpa.net
Sat Sep 16 01:45:58 PDT 2017
Please do.
It's easy to ignore formatting/whitespace changes in git, using git blame
-w / git diff -w, so even a major code formatting style change commit
shouldn't break history traceability. :)
сб, 16 сент. 2017 г. в 11:37, Sandro Santilli <strk at kbt.io>:
> On Thu, Sep 14, 2017 at 12:30:18PM -0400, Daniel Baston wrote:
> > Should this check .c, instead of .cpp ?
> Ouch, that's why it succeeded so easily ! :)
> So it looks like we have 2818 lines to be changed to make the
> correct test pass. Do you think I should proceed ?
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170916/c9efc3ad/attachment.html>
