[postgis-devel] MVT API Q?
Paul Ramsey pramsey at cleverelephant.ca
Tue Sep 26 05:08:50 PDT 2017
I'd say that, unless I'm misunderstanding, it's an ugliness, since correct
usage requires the user to both have a manually buffered box for the WHERE
and a original box for the MVT call.
  The user should be responsible for buffering their own box, so that the
WHERE box and the MVT box end up matching. So removing the MVT buffer
parameter and documenting the best practice of using a buffer.
P
On Mon, Sep 25, 2017 at 9:57 PM, Sandro Santilli <strk at kbt.io> wrote:
> On Mon, Sep 25, 2017 at 03:06:50PM -0700, Paul Ramsey wrote:
> > But, the features fed into ST_AsMVTGeom will have been themselves
> selected
> > using a bbox. If that is the same bbox as fed into ST_AsMVTGeom (makes
> > sense) then it's possible that there are features that *should* be in the
> > tile (because they fall within the buffered area, but not within the bbox
> > itself) are *not* in the tile.
> > I'd expect a user to provide the same box to ST_AsMVTGeom as they use in
> > the WHERE clause, but that means potentially there will be features
> missing.
> Are you asking why not passing an expanded box directly ?
> Or given your above description I'd say the expectance of using the
> same box for filtering and as a parameter to ST_AsMVTGeom is wrong
> and an HINT about that could be added to the manual...
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170926/3a030718/attachment.html>
