[postgis-devel] [MOTION] remove generated parser files from repo
Sandro Santilli strk at kbt.io
Tue Sep 26 06:43:31 PDT 2017
On Tue, Sep 26, 2017 at 05:05:26AM -0700, Paul Ramsey wrote:
> Having them checked in provides a certain stability and predictability.
Only if you don't accidentally override them as happens in Debbie.
Beside, there unpredictability also due to other dependencies
and to compiler being used and  flags passed it, so that aspect
should maybe be taken care of in a different way (official
build environment Docker?)
--strk;
