[postgis-devel] [postgis-users] PostGIS 2.4.0rc2 released
Greg Troxel gdt at lexort.com
Tue Sep 26 17:07:53 PDT 2017
Sandro Santilli <strk at kbt.io> writes:
> On Tue, Sep 26, 2017 at 09:19:49AM -0400, Greg Troxel wrote:
>> My overall suggestion is to back out this change, as it doesn't fix a
>> bug in the beta1/rc1/etc.  (Really, just to drop the no-trailing-blanks
>> token from the check dependencies.)
> Before doing that, could you check current tip of branch ?
> It should fix the .gitignore handling and the exclusion of
> generated files. Use of -P switch is still an issue though,
> but should easy to remove replacing it with:
>     grep -n '[[:space:]]$'
With the tip of svn-2.4 in git:
 commit 642b88404a16cee53b4e7cb03aa151295b4e1654 (HEAD -> svn-2.4,  origin/svn-2.4)
"gmake check" has no issues with the trailing space check, and seems
generally ok.
Thanks for the quick fix.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170926/77e4d97f/attachment.sig>
