[postgis-devel] Soft launch: PostGIS 2.2.7, 2.3.7, 2.4.4
Regina Obe lr at pcorp.us
Mon Apr 2 01:38:23 PDT 2018
> Hi Regina,
> On Mon, 2018-04-02 at 02:45 -0400, Regina Obe wrote:
>> I plan to do the official release of PostGIS 2.2.7, 2.3.7, 2.4.4 this
>> Friday.
>> I would appreciate if folks and in particular packagers do a test to
>> make sure all works well.
>> The tar balls are located here:
> <snip>
> What would it take to add PostgreSQL 10 "build" support to 2.2 branch? PostGIS RPMs ship "$majorversion - 1".so files for upgrade support. So, if we want to have 2.3 RPMs in PostgreSQL 10 repos, then 2.2 must be just built as well.
> This is what I'm getting:
> ---- Making all in libpgcommon
> make[2]: Entering directory '/var/lib/pgsql/git/pgrpms/rpm/redhat/master/postgis23/master/postgis-2.3.6/postgis-2.2.6/libpgcommon'
> Again, this is for upgrade purposes, and all I want is just a clean build.
> Regards,
> Devrim Gündüz
Why do you need 2.2 RPMs in PostgreSQL 10 repos?
2.3 builds for PostgreSQL 10, 9.6, 9.5, 9.4
We already have 10 for 2.3 upgrade only (though technically I think it would work for more than that)
2.4 is the version that should be officially shipping with PostgreSQL 10.
Your pathing looks a little weird here (why is 2.2.6 embedded in 2.3.6 ?) or is that so you can provide the .so?
And 2.2.7, 2.3.7 is what we are shipping now 2.2.6/2.3.6
If you really need it that badly, I would suggest making a copy of 2.3.so that you  built for 10 and calling it 2.2.so (it's safer than us trying to backport 10 changes to 2.2)
BTW this very mess is why I wanted to ditch the minor version so the lib would just be called postgis-2 (and we would maintain abi/sql level compatibility which we mostly do already) but lots of people seemed to have issue with that especially doing mid PostGIS 2 series.  It's on the table for PostGIS 3.
2.2 and 2.3 are abi and sql compatible.  2.3 just adds more functions, doesn't take any away that are needed to load 2.2.
Thanks,
Regina
