[postgis-devel] RectDistance
Paul Ramsey pramsey at cleverelephant.ca
Tue Feb 20 13:53:59 PST 2018
OK, it's in there, for those who want to try it out,
_ST_DistanceRectTree(g1 geometry, g2 geometry)
There is no caching in this version, so it's building and tossing away
the trees at every invocation.
P.
On Tue, Feb 20, 2018 at 1:49 PM, Bborie Park <dustymugs at gmail.com> wrote:
> +1
> On Tue, Feb 20, 2018 at 12:14 PM, Regina Obe <lr at pcorp.us> wrote:
>> No objections from me.  +1 to just bring it in 2.5.
>> I'm too lazy to test another branch, but if in place, I'd be willing to
>> test it out.
>> Thanks,
>> Regina
>> -----Original Message-----
>> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
>> Behalf Of Paul Ramsey
>> Sent: Tuesday, February 20, 2018 2:26 PM
>> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
>> Subject: [postgis-devel] RectDistance
>> Hey all,
>>   I've had a branch running for a while, that Nik has tested a little, for
>> tree-based distance calculations. I've been doing some testing on it and
>> finding that when it's good, it's very very good (10x improvements when
>> dealing with large geometries) and when it's bad, it's not so great (3x
>> worse than existing naive distance on small-vs-small geometries).
>>   All this so far without also reaching into the next obvious enhancement,
>> adding a caching behaviour, like the point-in-polygon/geos code. That will
>> make everything about 2x faster yet, as about 50% of the time seems to be
>> spent in building up trees.
>>   I'd like to merge my branch in, along with a temporary testing function
>> _ST_DistanceRectTree(geom, geom) so that we can figure out how we exactly
>> want to put this code to use. Any objections? If nothing else, it will
>> replace the current dead code lying in lwtree.c.
>> P.
>> postgis-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
