[postgis-devel] World Sinusoidal Projection in PostGIS
José María jmamuedo at gmail.com
Fri Jan 5 02:14:34 PST 2018
Thanks G. Allegri.
But the problem is I don´t get  any response with that query. So, that
means my PostGIS has not this srid=54008.
(Postgresql 9.6 PostGIS 2.0)
2018-01-05 11:06 GMT+01:00 G. Allegri <giohappy at gmail.com>:
> World sinusoidal is EPSG:54008 so I guess it's proj string [1] is already
> inside the spatial_ref_sys table, which is where CRS definitions are
> defined in PostGIS.
> You can verify it doing:
> SELECT * FROM spatial_ref_sys WHERE srid = 54008
> Giovanni
> [1] http://epsg.io/54008.proj4
> Il 5 gen 2018 10:46 AM, "José María" <jmamuedo at gmail.com> ha scritto:
>> Hi,
>> I spent several days searching info about how to use Worl Sinusoidal
>> porjection in PostGIS. But I didn´t find any responses.
>> I only found a possible codification (54008)  in ESRI, but I don´t know
>> how to manage this projection in PostGIS.
>> Any people can I help me with this discussion?
>> Thanks.
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180105/f0347d09/attachment.html>
