[postgis-devel] ST_DWithin Performance
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Sat Jan 6 07:58:39 PST 2018
Try swapping arguments so that first one has index and second does not.
Speaking of "always 20% faster", what are the plans for your queries?
сб, 6 янв. 2018 г. в 18:14, Zhihong Zhang <zhihong at gmail.com>:
> ST_DWithin is implemented like this,
> CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry,
> float8 RETURNS boolean
> AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND *$2
> OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3)* AND @extschema at ._ST_DWithin($1,
> $2, $3)'
> LANGUAGE 'sql' IMMUTABLE _PARALLEL;
> What’s the purpose of the second bounding box check?
> I did many tests. It’s always faster (about 20%) with one check. So we
> ended up using our own version of ST_DWithin.
> Thanks!
> Zhihong
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180106/f499b8db/attachment.html>
