[postgis-devel] Failing check_gdal test
Raúl Marín Rodríguez rmrodriguez at carto.com
Fri Jan 12 02:09:44 PST 2018
Hi there,
>From a long time I've had issues with the `check_gdal` test as it seems to
be
expecting gdal to not be configured if you unset `postgis.gdal_datapath` and
print something about "GDAL_DATA".
I've tested with PG 9.6, 10.1 and 11 and postgis 2.4 and trunk with the same
diff as my machine doesn't fail the configuration test
(rt_util_gdal_configured).
I'm attaching some of the tests I've made. Does anyone have a similar
problem or know how to avoid failing that test (besides manually removing
it)?
Regards,
*Raúl Marín Rodríguez *carto.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180112/54a224da/attachment.html>
postgis_reg=# Select postgis_gdal_version();
 GDAL 2.2.3, released 2017/11/20
(1 row)
postgis_reg=# SET postgis.gdal_datapath = '';
SET
(1 row)
postgis_reg=# SET postgis.gdal_datapath = 'invalid';
SET
(1 row)
postgis_reg=# Select postgis_full_version();
 POSTGIS="2.4.1 r16155" PGSQL="100" GEOS="3.7.0dev-CAPI-1.11.0 a51a06b1" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released 2017/
11/20" LIBXML="2.9.7" LIBJSON="0.13" LIBPROTOBUF="1.3.0" RASTER
(1 row)
postgis_reg=# Select version();
                                   version
 PostgreSQL 10.1 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 7.2.0, 64-bit
(1 row)
postgis_reg=# SET postgis.gdal_datapath = default;
SET
postgis_reg=# Show postgis.gdal_datapath;
(1 row)
                                   version
(1 row)
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180112/54a224da/attachment.obj>
