[postgis-devel] postgis 2.4.3 (and 2.3.6) release?
Paul Ramsey pramsey at cleverelephant.ca
Fri Jan 12 05:55:27 PST 2018
Backported the ST_Transform fix into 2.3 and 2.4.
I'm OK w/ patch releases.
P
On Fri, Jan 12, 2018 at 1:11 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Fri, Jan 12, 2018 at 12:52:08AM -0500, Regina Obe wrote:
>> Paul and Sandro,
>> Did you want to get the fix in for the ST_Transform schema qualification before we do the next release?
>> I would think that would be the only reason to hold up a release any longer.
> It looks like Paul nailed that already (but needs to be backported
> still ?)
> Rather, did we break pg_upgrade with that BRIN upgrade fix ?
> Or are we already recommending to upgrade postgis right after a
> pg_upgrade and thus are happy about it ?
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
