[postgis-devel] Failing check_gdal test
Paul Ramsey pramsey at cleverelephant.ca
Fri Jan 12 06:37:19 PST 2018
It's possible GDAL has gotten too smart for us in the time since that
test was written.
I'd be in favour of removing it, or replacing it with a simple
set/show pairing to prove we're in fact setting a GUC, for what that's
worth.
P.
On Fri, Jan 12, 2018 at 2:09 AM, Raúl Marín Rodríguez
<rmrodriguez at carto.com> wrote:
> Hi there,
> From a long time I've had issues with the `check_gdal` test as it seems to
> be
> expecting gdal to not be configured if you unset `postgis.gdal_datapath` and
> print something about "GDAL_DATA".
> I've tested with PG 9.6, 10.1 and 11 and postgis 2.4 and trunk with the same
> diff as my machine doesn't fail the configuration test
> (rt_util_gdal_configured).
> I'm attaching some of the tests I've made. Does anyone have a similar
> problem or know how to avoid failing that test (besides manually removing
> it)?
> Regards,
> carto.com
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
