[postgis-devel] [Internet] Re: make check fails on Solaris 11.3 with version 2.3.6
Dechaux Eric CEN (BCQ STIG) eric.dechaux at gendarmerie.interieur.gouv.fr
Sat Jan 20 00:12:34 PST 2018
Le 19/01/2018 à 21:11, Sandro Santilli a écrit :
> I don't understand why it is happening, LWORD is an typedef'd enum
> in liblwgeom.h, is your build not including the correct liblwgeom.h
> but rather a system one ? The order of those -I switches seem to
> indeed be unsafe (-I.. should probably be the first one)
You are right, It was using the wrong liblwgeom.h from postgis 2.1 and
the reason is the wrong -I order.
Thanks for your help.
-- Eric
Ce message électronique et tous les fichiers attachés qu'il contient sont confidentiels et destinés exclusivement à l'usage de la personne à laquelle ils sont adressés. Si vous avez reçu ce message par erreur, merci de le retourner à son émetteur. La publication, l'usage, la distribution, l'impression ou la copie non autorisée de ce message et des attachements qu'il contient sont strictement interdits.
En cas d'urgence, composez le 17 ou le 112.
Afin de contribuer au respect de l'environnement, merci de n'imprimer cet e-mail qu'en cas de necessite.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual to whom it is addressed. If you have received this email in error please send it back to the person that sent it to you. Unauthorized publication, use, dissemination, forwarding, printing or copying of this email and its associated attachments is strictly prohibited.
In case of emergency, dial number 17 or 112.
To contribute to the environmental protection, please print this e-mail only if necessary.
