[postgis-devel] smoothing function Chaikins algorithm
Darafei "Komяpa" Praliaskouski me at komzpa.net
Fri Mar 9 05:30:47 PST 2018
Please note that surnsme is Чайкин (Chaikin) and does not have "s" in it.
On пт, 9 сак 2018, 15.25 Regina Obe <lr at pcorp.us> wrote:
> Sure.  Something I've always wanted.
> As far as the name goes,  it would be nice to keep Chaikins in the name,
> but if you want the name to be searchable by purpose
> Perhaps something like  ST_ChaikinsSmooth
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
> Behalf Of Nicklas Avén
> Sent: Friday, March 09, 2018 5:03 AM
> To: postgis-devel at lists.osgeo.org
> Subject: [postgis-devel] smoothing function Chaikins algorithm
> Hello
> I have implemented chiakins algorithm for smoothing geometries.
> http://idav.ucdavis.edu/education/CAGDNotes/Chaikins-Algorithm/Chaikins
> -Algorithm.html
> <http://idav.ucdavis.edu/education/CAGDNotes/Chaikins-Algorithm/Chaikins-Algorithm.html>
> The algorithm is amazing simple
> Signature is:
> st_chaikins(geom geometry, n_iterations int, preserve_endpoints
> boolean)
> Do we want it in PostGIS?
> Should it be a more describing name than st_chaikins?
> The function more or less doubles the number of vertex points per
> iteration, so I have to put in a max number of iterations. I tried it with
> 40 iterations without thinking about it and it of course crashed the server
> It can be combined with some simplify function to again reduce number of
> verteces.
> The use case here is geometries generated from raster to smooth out the
> pixels.
> I have some cleanup to do before putting it somewhere.
> Thanks
> Nicklas
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180309/f7e3a06e/attachment.html>
