[postgis-devel] ST_Union Parallel Experiment
Regina Obe
lr at pcorp.us
Mon Mar 12 21:52:02 PDT 2018
Paul,
Well thanks for giving it a shot. I feared that would be the conclusion until ORDER BY in aggregates for parallelization is supported, which I don't have high hopes for given when I asked on hackers about their reason for not implementing it for string_agg., array_agg
https://www.postgresql.org/message-id/flat/000101d2df41%246feda800%244fc8f800%24%40pcorp.us#000101d2df41$6feda800$4fc8f800$@pcorp.us
That said, I do wonder if there is a benefit to having parallelization for ST_Collect. That often users don't care about having things ordered, then having collapsing 3 biggish geometry collections
May not save anything and I suppose you'd have to contend with ST_Collect (bunch_of_linestrings) is different from ST_Collect(bunch of multilinestrings) which would be the final.
ST_Union (rast) seems promising since I don't think it counts on an order anyway and is just building a big o'raster from smaller rasters in any order it gets.
Bborie, thoughts on if ST_Union(rast) for raster would be useful?
If I become brave enough I may attempt it for raster just to see how good or bad it is.
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Monday, March 12, 2018 6:48 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: [postgis-devel] ST_Union Parallel Experiment
Hey all,
I just wanted to record for posterity the results of my experiment in making a parallel version of ST_Union().
The basic theory was:
* add serialfn/deserialfn/combinefn to the aggregate
* in the serialfn, do an initial cascaded union of everything collected by the worker
* in the combinefn, do pairwise union of each set of partials
The obvious drawback is, particularly for inputs that are a "coverage"
(many polygons, covering an area, with no overlap) the workers won't be fed a neat contiguous area, so the main promise of cascaded union, that it eliminates the maximum number of vertices possible at each step, is broken.
In fact, that is more-or-less what I observed. The union was quite a bit slower, even when it was using up twice as much CPU (two core
laptop)
(The debug messages are the parallel-only functions
(serialfn/deserialfn/combinefn) being called in the parallel
execution.)
postgis25=# select st_area(st_union(geom)) from va_ply_17;
DEBUG: pgis_geometry_union_serialfn called
DEBUG: pgis_geometry_union_deserialfn called
DEBUG: pgis_geometry_union_deserialfn wkb size = 8526407
DEBUG: pgis_accum_combinefn called
DEBUG: pgis_geometry_union_deserialfn wkb size = 4236637
DEBUG: pgis_geometry_union_deserialfn wkb size = 6526511
st_area
1070123068374.1
(1 row)
Time: 106545.200 ms (01:46.545)
Force the plan to be single-threaded, and run again.
postgis25=# set max_parallel_workers_per_gather = 0; postgis25=# select st_area(st_union(geom)) from va_ply_17;
st_area
1070123068374.11
(1 row)
Time: 66527.914 ms (01:06.528)
Damn, it's faster.
It s possible that if the partials were fed inputs in a spatially correlated order the final merge might be no worse than the usual top-level merge in a cascaded union. However, forcing an ordering in the aggregate strips out the parallel plans.
postgis25=# set max_parallel_workers_per_gather = 2; postgis25=# explain select st_area(st_union(geom order by geom)) from va_ply_17;
QUERY PLAN
Aggregate (cost=15860.58..15860.62 rows=1 width=8)
-> Seq Scan on va_ply_17 (cost=0.00..1715.58 rows=5658 width=6181)
If the order by trick worked, I'd hope that the parallel execution might win, but since it doesn't it's best to just leave it "as is".
The branch is available here for anyone interested in perusing it.
https://github.com/pramsey/postgis/tree/svn-trunk-parallel-union
ATB,
P
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
