[postgis-devel] performance test suite
Regina Obe lr at pcorp.us
Tue May 1 13:42:46 PDT 2018
Bjorn,
Oh you are a man after my own heart.  Yes definitely.  Performance testing is a very weak spot in our testing.  I hate finding out about this when users complain :)
I think starting it off as a separate project is a good idea but I'd really love to see it eventually as part of PostGIS core that say we can flip on and have enabled for some bots or when we are about to release.  How we keep record of timings etc, seems to me a bot end thing the testing bot reporting to some mothership database.
As to whether it should be done in perl or something else – to be honest Perl scares the shit out of me.  Python sadly I haven't warmed up to either.  I always feel like I'm fumbling thru a mine field with both.  Okay that's an exaggeration.
But then again Perl is a dependency we are used to having, so whatever you do ideally shouldn't add any crazy dependencies and if additional dependencies – a dependency that can run on all platforms.  It's okay to have extra dependencies as long as they are not required for regular testing.  I think Komzpa already put in some logic for code coverage testing via lcov for example, which is fine since it's not a requirement.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Tuesday, May 01, 2018 1:08 PM
To: Björn Harrtell <bjorn at wololo.org>; PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] performance test suite
I think perhaps “do it as a separate project”. It’s going to be complex, it’s going to be brittle, it’s going to eventually break and I’d rather not have it sitting around broken inside the main source tree. The only way to find the regressions is going to be longitudinally testing and keeping track of numbers over time, so it’ll be quite a complex piece of work.
P
On May 1, 2018, at 10:05 AM, Björn Harrtell <bjorn.harrtell at gmail.com <mailto:bjorn.harrtell at gmail.com> > wrote:
Hi devs,
In recent times I've been pondering on about how to make a sensible test suite specifically for performance. Hacking/extending run_test.pl <http://run_test.pl/>  to accommodate for this has been the only suggested path forward but to me it's a dead end mostly because of perl (sorry)-
The reason why this has become a to me apparent missing thing is due to:
1. My own work on https://trac.osgeo.org/postgis/ticket/4076.
2. The recently discovered large performance regression of ST_Union tracked by https://trac.osgeo.org/postgis/ticket/4075. Even if it's in GEOS and could perhaps be performance tested there, I think it would not be wrong to also performance test ST_Union without consideration of underlying implementation.
Any additional thoughts on the subject? do it in perl or don't do it? :)
Regards,
/Björn
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180501/a85c0edb/attachment.html>
