[postgis-devel] address_standardizer build failed with postgresql 11devel changed
舒元昊 jincheng.jcs at gmail.com
Fri May 18 00:54:20 PDT 2018
Hi all:
    I'm new here, I don't know is it appropriate to report that issue via
mail list. If not, I apologize.
    I have builded postgis2.4.4 and postgis2.4.5dev with postgresql 11devel
today, and one error occured when `make` address_standardizer, here is the
error info:
>     std_pg_hash.c: In function ‘AddToStdPortalCache’:
> std_pg_hash.c:400:44: warning: passing argument 1 of ‘MemoryConte
> xtCreate’ makes pointer from integer without a cast [-Wint-conver sion]
>      STDMemoryContext = MemoryContextCreate(T_AllocSetContext, 819
> In file included from std_pg_hash.c:7:0:
> /mnt/e/app/postgres/include/server/utils/memutils.h:140:13: note: expected
> ‘MemoryContext {aka struct MemoryContextData *}’ but ar
> gument is of type ‘int’
>  extern void MemoryContextCreate(MemoryContext node,
> std_pg_hash.c:400:22: error: void value not ignored as it ought to be
> <builtin>: recipe for target 'std_pg_hash.o' failed
> make[2]: *** [std_pg_hash.o] Error 1
so I look at my postgresql and find out that MemoryContextCreate was a void
funcation, here is the code in utils/memutils.h
>  * This routine handles the context-type-independent part of memory
>  * context creation.  It's intended to be called from context-type-
>  * specific creation routines, and noplace else.
>                                         NodeTag tag,
>                                         const MemoryContextMethods
> *methods,
>                                         MemoryContext parent,
>                                         const char *name);
Now I think this is an error  caused by postgresql function change, am I
right ? So I should use a older version of postgresql ?
If what I think was wrong, pls help me.
Thank you very much!
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180518/93e6b86e/attachment.html>
