[postgis-tickets] [PostGIS] #2089: liblwgeom cannot be used through python ctypes
PostGIS trac at osgeo.org
Mon Dec 17 03:05:12 PST 2012
 Reporter:  brushtyler   |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  liblwgeom    |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Trying a build and testsuite run with this patch applied:
 cu_tester.c:97:31: error: ‘cu_errorreporter’ undeclared (first use in this
 function)
 I think the setter function to return the previous handler, so to allow
 for pluggable memory debugger or disk loggers. Or there should be another
 function to extract them. Current API does give direct access to the
 handler variables.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2089#comment:8>
