[postgis-tickets] [PostGIS] #2157: Redo ST_ConcaveHull utilizing Delaunay Triangulation
PostGIS trac at osgeo.org
Sat Dec 22 12:16:13 PST 2012
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 At the time I wrote ST_ConcaveHull, we didn't have ST_DelaunayTriangles so
 its much less efficient than it should be.
 http://www.postgis.org/documentation/manual-svn/ST_DelaunayTriangles.html
   The next version I was hoping to incorporate that logic, but that may
 require I have two versions since some people feel we need to support many
 versions of GEOS for each instance of PostGIS and I can't therefore
 require GEOS 3.4.0 without breaking backward compatiblity for some folks
 who are unfortunate enough to run 2.1 with anything less than GEOS 3.3.
 Next iteration, I'm planning to follow the other Sandro's approach as
 noted here:
 https://www.gaia-gis.it/fossil/libspatialite/wiki?name=tesselations-4.0
 As a side note - it would be nice if we had all those tessslation
 functions that Spatialite has as well since they are a common step in many
 workprocesses.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2157>
