[postgis-tickets] [PostGIS] #2158: Possible issue with gui loader/dumper on windows
PostGIS trac at osgeo.org
Wed Dec 26 11:00:24 PST 2012
 Reporter:  robe           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:  mingw,windows  |
 Winnie has started coughing up blood when doing PostgreSQL 9.2.1 32-bit
 tests on loader/dumper gui.  It's weird it is the only one and it started
 happening oddly enough when I made changes to PostGIS tiger geocoder
 extension which in theory should have nothing to do with the dumper gui. I
 tried rerunning regress to rule out flukiness and still failed.  I'll
 reboot the server later to see if that helps.
      CUnit - A unit testing framework for C - Version 2.1-2
      http://cunit.sourceforge.net/
 Suite: Shapefile Loader File shp2pgsql Test
   Test: test_ShpLoaderCreate() ...passed
   Test: test_ShpLoaderDestroy() ...make[2]: *** [check] Error 128
 make[2]: Leaving directory `/c/jenkins/postgis/branches/2.1/loader/cunit'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/c/jenkins/postgis/branches/2.1/loader'
 make: *** [check] Error 1
 Debbie doesn't do the gui test at all so hard to compare.  I'm retesting
 on 9.1x64 to see if it will also fail to suggest flukiness.
 Err 128 seems to be often caused by paranoid antivirus software so might
 be just the recent virus definition updates and have nothing to do with
 PostGIS.
 strk -- no wise ass comments about windows :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2158>
