[postgis-tickets] [PostGIS] #1627: package tiger_geocoder as a PostgreSQL extension
PostGIS trac at osgeo.org
Thu Dec 27 14:38:49 PST 2012
 Reporter:  robe            |       Owner:  robe
     Type:  enhancement     |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.1.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 This is functioning as of r10934.
 So now it is possible to
 CREATE EXTENSION postgis_tiger_geocoder;
 And if you have latest 2.1.0 installed without using an extension
 convert to extension model with
 CREATE EXTENSION postgis_tiger_geocoder FROM unpackaged;
 I still need to stress test, update the docs, and also implement the
 UPDATE EXTENSION logic before I can consider this closed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1627#comment:4>
