[postgis-tickets] [PostGIS] #2258: Can't upgrade from 2.1.0 to 2.1.0 when postgis in non-default schema
PostGIS trac at osgeo.org
Mon Apr 1 18:39:52 PDT 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Confirmed, its only an issue if you have postgis installed in non-public.
 IF I do this with this database:
 ALTER EXTENSION postgis SET SCHEMA public;
 ALTER EXTENSION postgis UPDATE TO "2.1.0SVNnext";
 ALTER EXTENSION postgis SET SCHEMA postgis;
 Works fine but of course no one should be required to go thru hoops like
 this just because they want to keep the trillions of functions of postgis
 away from their core data.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2258#comment:1>
