[postgis-tickets] [PostGIS] #468: ST_MakeEllipse geometry
PostGIS trac at osgeo.org
Tue Apr 2 01:23:57 PDT 2013
 Reporter:  Epzt     |       Owner:  pramsey
     Type:  patch    |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:  ellipse  |
Comment(by strk):
 Epzt, if you're still reading, could you also add CUnit testcase for the
 new functionality ?
 Also is the "direction" parameter compatible with the return from
 ST_Azimuth ? And would it make more sense for "nedges" to be expressed
 per-quadrant, to be consistent with what ST_Buffer takes ?
 Unified diff format would be preferred.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/468#comment:3>
