[postgis-tickets] [PostGIS] #1461: Tiger Geocoder doesn't anticipate irregular spacing in road name
PostGIS trac at osgeo.org
Tue Apr 2 05:35:46 PDT 2013
 Reporter:  arencambre           |       Owner:  robe
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by woodbri):
 I should correct my last comment, PAGC still parses based on token so
 names like "SUN VALLEY" will parse as two tokens and "SUNVALLEY" will
 parse as one token. In my geocoder, I handle this under the fuzzy search
 by joining all the name tokens, then picking the best match to the input
 via scoring the results.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1461#comment:6>
