[postgis-tickets] [PostGIS] #2262: autocast to box causing issues with removed functions
PostGIS trac at osgeo.org
Wed Apr 3 16:37:28 PDT 2013
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 Bruce Rindahl pointed out to me that he was in the habit of using the
 area function and when he upgraded to 2.0, he could still use the area
 function, but it was now returning a different answer from ST_Area.  I
 think the wrong answer.  I did a test myself on a pure 2.0 install, and
 came up with the same disturbing answer.  Seems our geometries are falling
 into the built in box type is my guess and enjoying te fruits of using box
 area functions.
 Demonstration:
 select st_area(ST_Buffer(ST_MakeEnvelope(1,2,3,4),1)) As our_area,
 area(ST_Buffer(ST_MakeEnvelope(1,2,3,4),1)) As our_geom_found_in_box,
 area(ST_Buffer(ST_MakeEnvelope(1,2,3,4),1)) As explicit_cast_box
 All kinda disturbing:
      our_area     | our_geom_found_in_box | explicit_cast_box
  15.1214451522581 |                    16 |                16
 I suppose we could just bring back area and length to prevent this from
 happening.  I suspect those might be the only two.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2262>
