[postgis-tickets] [PostGIS] #2258: ST_Estimated_Extent assumes postgis is installed in public
PostGIS trac at osgeo.org
Wed Apr 3 23:07:37 PDT 2013
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  blocker                |   Milestone:  PostGIS 2.1.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Okay changed at r11249
 I didn't go thru the trouble of trying to stab my finger, but it installs
 now even if my postgis is in a different schema.  I added SECURITY
 INVOKER, but that is just more syntactic deliberance than anything since
 that is the default behavior anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2258#comment:6>
