[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
PostGIS trac at osgeo.org
Wed Apr 3 23:22:02 PDT 2013
pagc_address_parser
 Reporter:  robe                 |       Owner:  robe
     Type:  task                 |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by robe):
 I am concerned about the 8401 W 35W regression failure if use PAGC, though
 I suspect this may just require adding an entry to pagc_gaz or pagc_lex to
 accommodate.
 The Wizard of OZ one, well it is a made up address so not quite so
 bothered it doesn't match with what I'm expecting :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:2>
