[postgis-tickets] [PostGIS] #1802: Ensure interruptability of long-running calls
PostGIS trac at osgeo.org
Thu Apr 4 00:20:08 PDT 2013
 Reporter:  strk     |       Owner:  strk
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 I belive this is open as it's missing testcases.
 A testcase could do something like setting a very short statement timeout
 and invoking a very expensive GEOS query. It'd be a pretty fuzzy test in
 that it's success would depend by the timeout being long enough not to
 kick before GEOS starts and short enough not to kick after GEOS ends, and
 it will be also dependent on GEOS, and on the machine. Tricky one.
 Maybe the test should be independent from the others and first run the
 expensive query once to time it, then set timeout to half of that and run
 again, taking in consideration also cold vs. warm runs...
 Did anyone get excited enough to work on it ? :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1802#comment:31>
