[postgis-tickets] [PostGIS] #2263: [raster] Audit usage of serialize/deserialize vs wkb/hexwkb
PostGIS trac at osgeo.org
Thu Apr 4 11:24:20 PDT 2013
 Reporter:  dustymugs  |       Owner:  dustymugs
     Type:  task       |      Status:  new
 Priority:  high       |   Milestone:  PostGIS Future
Component:  raster     |     Version:  trunk
 Keywords:             |
 An audit needs to be done to delineate the usage of serialize/deserialize
 and wkb/hexwkb.  At the present time, serialize/deserialize and wkb/hexwkb
 are the same and has possibly caused the blind usage of wkb/hexwkb when
 serialize/deserialize is appropriate and vice versa.
 The key difference between serialize/deserialize and wkb/hexwkb is:
 1. serialize/deserialize: Internal storage format.  The output seen from a
 query like the following should be of this format.
 SELECT rast FROM mytable
 2. wkb/hexwkb: Transport format.  This format is meant for use by and must
 be explicitly called for by clients.  To get wkb/hexwkb output, the
 clients must use ST_AsBinary().
 The rational for this is so that in the future, these two formats can
 deviate from each other (particularly the internal storage format).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2263>
