[postgis-tickets] [PostGIS] #2257: totally non-sensical regress failure with empty tickets.sql
PostGIS trac at osgeo.org
Sat Apr 6 10:11:27 PDT 2013
 Reporter:  robe         |       Owner:  robe
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  postgis      |     Version:  trunk
 Keywords:  mingw64-w32  |
Comment(by dustymugs):
 I think this might be a compound issue.  In looking at the code for
 lwgeom_eq() in postgis/lwgeom_btree.c, it is failing on the second if/else
 evaluation around line #195.  Both input geometries result in the
 variables empty1 and empty2 being TRUE.
 The problem is that the second test compares the coordinates for the
 boxes, which are uninitialized (so says valgrind when running in Linux
 64-bit)...
 Adding some additional debug output...
 POSTGIS_DEBUGF(3, "empty1, empty2 = %d, %d", empty1, empty2);
 POSTGIS_DEBUGF(4, "%f ~ %f, %f ~ %f, %f ~ %f, %f ~ %f",
         box1.xmin, box2.xmin, box1.ymin, box2.ymin, box1.xmax, box2.xmax,
 box1.ymax, box2.ymax);
 results in...
 NOTICE:  [lwgeom_btree.c:lwgeom_eq:189] empty1, empty2 = 1, 1
 NOTICE:  [lwgeom_btree.c:lwgeom_eq:191] 0.000000 ~ 0.000000, 0.000000 ~
 0.000000
 , 0.000000 ~ 1.#INF00, 0.000000 ~ 0.000000
  ?column?
  f
 (1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2257#comment:5>
