[postgis-tickets] [PostGIS] #2193: Utilize PAGC parser as drop in replacement for tiger normalizer
PostGIS trac at osgeo.org
Sun Apr 7 06:49:40 PDT 2013
 Reporter:  robe                 |       Owner:  robe
     Type:  enhancement          |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by woodbri):
 No we also need branches/sew-refactor/parseaddress/. The current process
 to install this is too complicated and looks like:
  * build and install library in parseaddress
  * build and install library in pagclib/api
  * build and install plpgsql wrapper code in pagclib/api/psql
 There is no reason that all the required pieces can not be pulled into a
 single directory and all be linked into a single postgresql library. This
 would make the maintenance of it much cleaner from the postgis point of
 view. I will look into doing this shortly.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2193#comment:14>
