[postgis-tickets] [PostGIS] #2266: GEOS requirement misstated
PostGIS trac at osgeo.org
Mon Apr 8 08:57:41 PDT 2013
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  2.0.x
Resolution:  invalid  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Ah okay then no problem.  I was right. Though I didn't think topology
 tried to install if it had a lower GEOS.
 I'll close out as a non-issue, but we probably should have one buildbot
 test against 3.2.  Setting up debbie to do that now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2266#comment:4>
