[postgis-tickets] [PostGIS] #2213: postgis-2.1.so: undefined symbol: json_tokener_errors
PostGIS trac at osgeo.org
Tue Apr 9 13:19:15 PDT 2013
 Reporter:  mloskot  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:  json-c   |
Comment(by kashif):
 It could also be that because he's using the git version, it does not have
 json_tokener_errors[] as a public api, but instead the new api is to use
 the json_tokener_error_desc(...) method.
 So we will need to check that when this happens in the official json-c
 release. But for now, we would suggest that you remove your installation
 of json-c and use the official one from ubuntu via: sudo apt-get install
 libjson0-dev
 I hope this helps!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2213#comment:4>
