[postgis-tickets] [PostGIS] #2269: Unreasonable memory usage when analyzing table with geometry column with many toasted datums
PostGIS trac at osgeo.org
Tue Apr 9 13:39:50 PDT 2013
many toasted datums
  Reporter:  pgeoghegan  |       Owner:  strk
      Type:  defect      |      Status:  reopened
  Priority:  high        |   Milestone:  PostGIS 2.0.4
 Component:  postgis     |     Version:  2.0.x
Resolution:              |    Keywords:  toast,leak
Comment(by robe):
 You change to 2.0 branch appears to be causing debbie to crash on 8.4
 test.
 PostgreSQL 8.4.17 on x86_64-unknown-linux-gnu, compiled by GCC gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
  Postgis 2.0.4SVN - r11273 - 2013-04-09 20:27:06
    GEOS: 3.3.9dev-CAPI-1.7.9
    PROJ: Rel. 4.7.1, 23 September 2009
 Running tests
  loader/Point ....................... ok
  loader/PointM ....................... ok
  loader/PointZ ....................... ok
  loader/MultiPoint ....................... ok
  loader/MultiPointM ....................... ok
  loader/MultiPointZ ....................... ok
  loader/Arc ....................... ok
  loader/ArcM ....................... ok
  loader/ArcZ ....................... ok
  loader/Polygon ....................... ok
  loader/PolygonM ....................... ok
  loader/PolygonZ ....................... ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint ............... ok
  loader/MultiToSinglePoint ......... ok
  loader/ReprojectPts ........ ok
  loader/ReprojectPtsGeog ........ ok
  loader/Latin1 .... ok
  binary .. ok
  regress .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  out_geometry .. ok
  out_geography .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. ok
  dump .. ok
  dumppoints .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_66_diff)
  typmod .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_67_diff)
  remove_repeated_points .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_68_diff)
  split .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_69_diff)
  relate .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_70_diff)
  bestsrid .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_71_diff)
  concave_hull .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_72_diff)
  hausdorff .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_73_diff)
  regress_buffer_params .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_74_diff)
  offsetcurve .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_75_diff)
  relatematch .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_76_diff)
  isvaliddetail .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_77_diff)
  sharedpaths .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_78_diff)
  snap .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_79_diff)
  node .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_80_diff)
  unaryunion .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_81_diff)
  clean .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_82_diff)
  relate_bnr .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_83_diff)
  in_geojson .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_84_diff)
  uninstall . failed (uninstall_postgis.sql failed:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/uninstall.err)
 .psql: FATAL:  the database system is in recovery mode
 dropdb: could not connect to database postgres: FATAL:  the database
 test: 1052: Something: unexpected operator
  ok (3699)
 Run tests: 85
 Failed: 20
 make[1]: *** [check] Error 20
 make[1]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/branches/2.0/regress'
 make: *** [check] Error 1
 Build step 'Execute shell' marked build as failure
 An attempt to send an e-mail to empty list of recipients, ignored.
 Finished: FAILURE
 I retested to make sure it wasn't a fluke and crsashed the second time in
 same spot
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2269#comment:4>
