[postgis-tickets] [PostGIS] #2269: Unreasonable memory usage when analyzing table with geometry column with many toasted datums
PostGIS trac at osgeo.org
Tue Apr 9 14:46:22 PDT 2013
many toasted datums
  Reporter:  pgeoghegan  |       Owner:  strk
      Type:  defect      |      Status:  reopened
  Priority:  high        |   Milestone:  PostGIS 2.0.4
 Component:  postgis     |     Version:  2.0.x
Resolution:              |    Keywords:  toast,leak
Comment(by pramsey):
 I'd expect trunk to blow chunks too,
 http://trac.osgeo.org/postgis/browser/trunk/postgis/geometry_estimate.c?rev=11274#L938
 the edit means that VARSIZE is being called on... something? Just pfreeing
 the geom at the end of the loop might be the preferred approach. Or, find
 out what we're supposed to be saving into stawidth, since that's black
 magic.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2269#comment:6>
