[postgis-tickets] [PostGIS] #2269: Unreasonable memory usage when analyzing table with geometry column with many toasted datums
PostGIS trac at osgeo.org
Tue Apr 9 15:17:36 PDT 2013
many toasted datums
  Reporter:  pgeoghegan  |       Owner:  strk
      Type:  defect      |      Status:  reopened
  Priority:  blocker     |   Milestone:  PostGIS 2.0.4
 Component:  postgis     |     Version:  2.0.x
Resolution:              |    Keywords:  toast,leak
Comment(by strk):
 @pramsey, while I sleep maybe you're able to figure out if we need the
 TOASTED or DETOASTED value size in that field ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2269#comment:9>
