[postgis-tickets] [PostGIS] #2269: Unreasonable memory usage when analyzing table with geometry column with many toasted datums
PostGIS trac at osgeo.org
Tue Apr 9 15:45:08 PDT 2013
many toasted datums
  Reporter:  pgeoghegan  |       Owner:  strk
      Type:  defect      |      Status:  reopened
  Priority:  blocker     |   Milestone:  PostGIS 2.0.4
 Component:  postgis     |     Version:  2.0.x
Resolution:              |    Keywords:  toast,leak
Comment(by strk):
 r11275 in 2.0 and r11276 in trunk
 It's still to be researched what effects will the stawidth change have on
 the planner.
 Maybe it'll consider sequential scans cheaper. Did you ever work on that
 testing support for planner pramsey ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2269#comment:11>
