[postgis-tickets] [PostGIS] #2272: shp2pgsql-gui crashes when given filenames with dots
PostGIS trac at osgeo.org
Fri Apr 12 21:05:00 PDT 2013
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.4
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Changes (by robe):
  * priority:  high => medium
Comment:
 Same issue with shp2pgsql except shp2pgsql doesn't crash, just gives a
 can't locate .dbf.  However with shp2pgsql I can work around the issue by
 explicitly referencing the .dbf file and weirdly it has not problems
 finding the companion .shp file.
 If I try to do the same with shp2pgsql-gui (pointing it at the dbf instead
 of shp)and it  STILL complains it can't find the .dbf and crashes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2272#comment:1>
