[postgis-tickets] [PostGIS] #1657: Crasher on ST_AsLatLonText on mingw64
PostGIS trac at osgeo.org
Fri Apr 19 02:17:16 PDT 2013
 Reporter:  robe                    |       Owner:  strk
     Type:  defect                  |      Status:  assigned
 Priority:  critical                |   Milestone:  PostGIS 2.0.4
Component:  postgis                 |     Version:  trunk
 Keywords:  mingw64, windows 64bit  |
Comment(by strk):
 I cant get no valgrind reported error with your test. Crystal clear.
 Only ERROR:  Bad format, degrees (DD.DDD) must be included.
 And the postgresql always present write(buf) to uninitialize bytes at
 startup.
 This is with postgresql 9.2.1, on a 64bit host -- what version are you
 running ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1657#comment:17>
