[postgis-tickets] [PostGIS] #1657: Crasher on ST_AsLatLonText on mingw64
PostGIS trac at osgeo.org
Fri Apr 19 06:16:24 PDT 2013
 Reporter:  robe                    |       Owner:  strk
     Type:  defect                  |      Status:  assigned
 Priority:  critical                |   Milestone:  PostGIS 2.0.4
Component:  postgis                 |     Version:  trunk
 Keywords:  mingw64, windows 64bit  |
Comment(by robe):
 -- crashes --
 POSTGIS="2.1.0SVN r11294" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" (core procs from "2.1.0SVN r11230" need upgrade) RASTER
 (raster procs from "2.1.0SVN r11230" need upgrade);PostgreSQL 9.2.2,
 compiled by Visual C++ build 1600, 64-bit
 -- gives this notice in postgres logs --
 LOG:  server process (PID 3784) was terminated by exception 0xC0000409
 DETAIL:  Failed process was running:
         SELECT ST_AsLatLonText(foo1.the_geom, 'monkey') As result FROM
 ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom FROM (SELECT
 a*1.11111111 FROM generate_series(-10,50,2) As a) As i(i) CROSS JOIN
 generate_series(40,70, 5) j ORDER BY i,j )) As foo1 LIMIT 3;
 HINT:  See C include file "ntstatus.h" for a description of the
 hexadecimal value.
 LOG:  terminating any other active server processes
 WARNING:  terminating connection because of crash of another server
 process
 -- just throws error --
 LIBJSON="UNKNOWN" RASTER;PostgreSQL 9.2.2 on x86_64-w64-mingw32, compiled
 by x86_64-w64-mingw32-gcc.exe (GCC) 4.5.4 20111030 (prerelease)
 [svn/rev.180676 - mingw-w64/oz], 64-bit
 ERROR:  Bad format, degrees (DD.DDD) must be included.
 It doesn't seem to happen on my mingw64 postgresql compiled.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1657#comment:18>
