[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
PostGIS trac at osgeo.org
Sat Apr 20 07:06:55 PDT 2013
pagc_address_parser
 Reporter:  robe                 |       Owner:  robe
     Type:  task                 |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by woodbri):
 I just integrated a test_main target to the makefile so you can not run
 the address standardizer (not parseaddress) outside of the database in the
 src directory as it reads some support files from there.
 I ran valgrind on this and it is clean on the linux system. I'll try to
 build it in minggw and see if it runs there or throws an error.
 You can ru it like this:
 make test_main
 ./test_main
 123 cambridge st
 boston ma 01002
 exit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:10>
