[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
PostGIS trac at osgeo.org
Sat Apr 20 16:51:32 PDT 2013
pagc_address_parser
 Reporter:  robe                 |       Owner:  robe
     Type:  task                 |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by robe):
 Steve,
 Sorry this is a little embarassing, I just tried the old version and it
 crashed as well.  Then I realized the new one actually works on my EDB
 install just fine like I thought it did before.  I think I was testing
 with a NULL address when I thought it didn't work (like sample above), and
 like you said it crashes on NULL in windows.
 So it seems the mingw one is probably failing because Cassert is enabled
 in my mingw install and you always saw  failure because you always test in
 mingw (and I always swap back to VC++ one because I know that is what
 people will be using) and my VC EDB is not compiled with cassert because
 its production version.  I'll do a couple more tests to make sure we are
 not seeing things and also recompile a mingw version without cassert
 enabled to see if it works.
 That said is your Linux version compiled with cassert enabled?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:16>
