[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
PostGIS trac at osgeo.org
Sat Apr 20 18:17:29 PDT 2013
pagc_address_parser
 Reporter:  robe                 |       Owner:  robe
     Type:  task                 |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by robe):
 Okay the good news.  All tests on my mingw64 postgresql pass if I compile
 without the debug or cassert flags.
 So building like this:
  -- No crash
 ./configure --prefix=${PROJECTS}/pgx64/pg${PG_VER} \
  --build=x86_64-w64-mingw32 \
  --host=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 \
  --with-pgport=8442 --disable-float8-byval \
  --enable-integer-datetimes --without-zlib
 building like this:
  -- Crashes --
  --with-pgport=8442 --disable-float8-byval --enable-cassert --enable-debug
 So either the mingw has a bug in the debugging/or cassert logic or its
 catching things your Linux one isn't because your linux is not compiled
 with debug and cassert flags.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:20>
