[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
PostGIS trac at osgeo.org
Sun Apr 21 06:08:26 PDT 2013
pagc_address_parser
 Reporter:  robe                 |       Owner:  robe
     Type:  task                 |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by woodbri):
 Ok posted the problem on the pgsql-hackers list and Tom Lane replied with:
   You can't hold a SPI context open across multiple calls of an SRF.
   Even if it somehow failed to malfunction in isolation, this would
   certainly not work in a query where some other called function was
   also using SPI.
   Possibly the reason the code accidentally fails to malfunction on Linux
   is you're not using an --enable-cassert build there?  That would wipe
   freed memory and thus help to reveal errors of this sort consistently,
   whereas otherwise the failures would be context-dependent.
 So I guess I have to figure out how to save the contents of my
 SPI_tuptable into another context that can be held across SRF calls.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:22>
