[postgis-tickets] [PostGIS] #2275: doxygen building is broken
PostGIS trac at osgeo.org
Sun Apr 21 21:35:29 PDT 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 Just noticed Debbie can't build doxygen anymore after
 r11304
 error is:
 configure: error: could not find pg_config within the current path. You
 may need to try re-running configure with a --with-pg_config parameter.
 I put in a distclean and that didn't help.  Doesn't seem to affect regress
 so maybe something needs changing in doxygen logic?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2275>
