[postgis-tickets] [PostGIS] #2275: doxygen and html/pdf document building is broken (was: doxygen building is broken)
PostGIS trac at osgeo.org
Sun Apr 21 21:58:14 PDT 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 To add also broke the doc building job.
 http://debbie.postgis.net:8080/job/PostGIS_2.1_docs/
 checking for iconvctl... no
 checking for libiconvctl... no
 checking for pg_config... no
 configure: error: could not find pg_config within the current path. You
 may need to try re-running configure with a --with-pg_config parameter.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2275#comment:2>
